Metroidman
Member
I'm on Synergy Rom
Where did you end up buying your extended battery for the TB? And how much did it cost? Is it the one that has a bulge on the back? And if so, what sort of cover are you using? Thanks.
I had a Seidio slim battery, but it seemed like it didn't hold the charge the entire day for me. Then I lost it. ;-( So now I have to buy another battery.
Well...imo, the ebay batteries work just as well as OEM(I have three OEM batteries and one(I sold one and gave another away) ebay batteries and they all work the same.) from my experience.
3500mAh Extended Battery + Cover For HTC Thunderbolt 4G | eBay![]()
Is one idea, I personally got this one and love it. The dock alone is worth it.
New 7 Battery Charger Case For Htc Thunderbolt 4G | eBay![]()
Synergy ftw btw.
I have a dock already for the smaller sized Seidio, so I don't need that. I had lost the Innocell 1600mAh Slim Extended Life Battery. But it didn't seem to be able to keep my phone fully charged for a day either. I wasn't sure whether the bulk of the 3500mAh Extended Battery would be worth it. How are you getting around the form factor? It's not too easy to put in your pocket.
seidioonline.com
seidioonline.com
I see that a seller is from China. It also says they are not responsible for custom or duty fees. Have you ever dealt with orders from China to the US? Thanks.
I've been using the 1700mAh from htcexpress since about April and it's been my daily battery ever since then. It gives me an extra 4-6 hours, depending on use and I don't have that horrendous, embarrassing hump in the middle of my phone
Love it.I've been using the 1700mAh from htcexpress since about April and it's been my daily battery ever since then. It gives me an extra 4-6 hours, depending on use and I don't have that horrendous, embarrassing hump in the middle of my phone
