Hawker
Android Expert
I installed the performance mod for Siyah. Upon examination I found that it places a file in system/etc/init.d called 01performance. files in the init.d folder are what get executed when the device boots up.
as I got a big drain overnight, I decided to run the kernel cleaner script and re-install the Siyah kernel itself, expecting this to clear the tweak. I then looked in the init.d folder again only to find this file still there. Therefore, the tweak still gets executed on bootup, and is still active. I am wondering now whether or not to manually remove the file.
It concerns me as I installed Ragemod, and this file is STILL there, so I'm a little worried as to what places files in the startup scripts folder, and the fact that many such files may be lingering there unnecessarily. Chances are these scripts have been built up from previous kernel tests and tweaks etc, so worried as to what is getting run at startup that perhaps shouldnt be. This could be the cause of so many people having such varying results with kernels.
I was wondering:
1. What are the standard init.d script file names (if any)? Is 01performance a modded default file, or a new one added by this siyah tweak
2. as well as /system/etc/init.d, there is also /etc/init.d. This appears to be a copy of /system/etc/init.d. What is the difference? Does one take precedence over the other? If a file is removed from one folder, will the other get run instead?
in my /system/etc/init.d (and therefore /etc/init.d) folder I have the following files:
i also have in here:
01performance
05module
90ram-tweaks
98mounts
99complete
S02modules
What do you have in yours?
I was wondering:
01performance
05module
90ram-tweaks
98mounts
99complete
S02modules
