Portable Wi-Fi hotspot is a hidden settings![]()
1. search "quick settings" by halfbit on the market and install it
2. open quick settings and press the menu button, its left from the home
3. "customize", scroll down to the "hidden settings" and drag "Wi-Fi hotspot" up to the "visible settings"
no root needed
you have to go into the "Configure Wi-Fi hotspot"
to get the password or change it to 1234567890
no root needed
I cannot select the configure either. When I try to turn it on I get an error.
Which app are you guys using to tether with?
Barnacle works...I just tried barnacle and wifi tether for root with no success. Barnacle showed some signs that it was trying but with no luck.
My tether worked before, but it's not working after zv9 update. I was wondering if anyone is having the same problem as me.
