C
CramRazz
Guest
I'm really liking Cyanogen 6.1 right now. I ran MIUI for 2 weeks without a problem, but then issues started cropping up.
Virtuous is the most stable ROM I've found. No FCs, no error messages. Easy to use and set up.
Just flashing RR Sense-less right now, im a huge fan of LauncherPro and it seems like this might be a good fit.
Thanks all, keep suggestions coming!
I just rooted. Have yet to flash a ROM. I LOVE Launcher Pro Plus. I want better battery. I am a BIGTIME NOOB. What would be the best 1st ROM to flash for ME?
(Does it matter how you rooted? I used Unrevoked3)
does not matter how you root.
What is launcherpro plus? I usa launcherPro, not sure is there another version?
what are the added features? Im a huge fan of launcher pro
Launcher Pro Plus is the paid version of Launcher Pro that allows you to resize widgets and adds HTC Sense-like widgets
Try IncROM V1.0.. It's on Rom Manager now..
Very stable
I got my notification bar and battery in the same zip. It's a circle with your battery percent in the middle.
Worm, I cannot find that mod for MW2.2, do you have a link?
It was a zip for the normal task bar, green power widget and super circle battery. Let me see if I can find it for you..found it here you go. I'm sure you're well aware and will do this regardless but backup before flashing
Normal Taskbar-Green Widget-Super Circle.zip
This is a link to the thread I found the zip in over at xda
Well, it's the holidays and I'm bored at work so I think I'm gonna try some ROM flashing. Just a few quick questions before I take the plunge:
1. Someone recommended [KERNEL] 2.6.32.26-incredikernel-12/13/2010-2(if you downloaded 12/13 please update!) - xda-developers for a great battery saving kernel. Can I use this with the latest Virtuous ROM or do I need a special kernel?
2. Due to being at work and I'd like it to be easy...can I use a ROM manager from the market to grab a new kernel and ROM?
3. If I hate everything can I use my Nandroid Backup to restore my old ROM and Kernel or just the ROM?
Thanks!!!
Ya know, I saw that page on XDA and cause it was green (probably blue when plugged in?) I thought it was something else.
Thanks for your help!!
