GalaxyNexus
I just got a new screen protector for my Nexus (Zagg Invisashield) and I found that my VZW branded case doesn't work with it. So, what cases are all you guys using?
Based on my experience, the case will cause the screen protector to bunch up. Perhaps that is what OP is referring to?A screen protector that won't work with a CASE?
Isn't the screen protector the exact dimensions of the screen? I don't understand...
Anyway, no case here. Just an XO Skin screen protector and a Verizon-branded extra-large horizontal holster for my belt![]()
Never heard of it. I've used screen protectors since my LG Dare days and never had one "bunch up". It adheres beautifully to the screen with no overlap to bunch.
I guess I'm the lucky one or something![]()
Cruzer lite
Im using a black gel TPU case I got from Amazon. It protects great and it comes off and on easily
Case? ya, I don't use a case. That's like telling a playboy playmate to put her clothes back on.
Yeah, until that playmate breaks her leg jumping off the roof from one of her many cocaine filled evenings. I kept my Droid X naked for a long time, and dropped it quite a few times as well. But, to my dismay, I dropped it just right to get a cracked digitizer. I now choose to use a case.
OP, are you using an extended battery, or plan on buying one? That will significantly decrease the number of available cases for you. I'm on Verizon and picked up the 2100 mAh extended battery. I searched for ages for a sleek case that accommodated the battery. I found the Diztronic Rev 3 to be perfect! It's slim, looks great, and even adds more grip. Which, by the way, the naked Nexus has horrible grip. Thus another reason to buy a case! Happy shopping! :wavey:
