Root What do these do???
malice777
Member
Can anyone explain to me what these settings are for?? Plz n thanks
I don't know exactly what they do but I turn my cache pressure down to 25. I clear caches alot on my phone anyways.
I know there was a post somewhere here that had some custom setting that supposedly worked better.
I'll leave the explanation to the smarter people ;)
Yea its in rom tool box under kernel tweaks.......what i want too know is what all these tweaks do.....dirty ratio??? Wtf is that.....im trying to become well educated as far as flashing and stuff like this, so i really want to know exactly what all this stuff does.....
They do nothing that you will notice.
There's a reason why the "Devs" spend countless hours in creating the ROMS and kernels. I trust their judgement and I seriously doubt I could ever "tweak" something so miniscule that it would be for the better.
Your best bet is too leave it alone.
Go play with the build.prop if you wanna play with something that will actually change your phone. :D
If you REALLY wanna know, I took the liberty of using this real quick, Search Function, from which I found an old post that I made titled ROM toolbox kernel tweaks. ;)
http://androidforums.com/esteem-all-things-root/534034-rom-toolbox-kernel-tweaks.html
