I must say, the DHD has an excellent battery.
The battery is piss poor, end off, fact, but i still love my DHD.
Out of interest is that battery monitor your using built in or an app? I know you can check some of those in the battery settings but not in so much detail.
It must be something to do with phone signal, because when it has no signal or a poor one the phone will try at certain intervals to try and pinpoint a signal. If it does this every 30seconds then it could easily be the cause.
Do you mean the battery use graph?
"menu=>settings=>about phone=>battery use"
I do love the phone but I find the battery life horrendous!
I need to look into why the phone is awake 100% of the time, I didn't realise that particular item should be showing awake all the time??
On the other screen where you can see the % used per item and 57% screen, 10% Android, 10% WiFi etc...
Nothing is showing major usage..
OP: Here is a newly developed app from XDA for you to install and find out what it is keeping your phone awake. When you find it please let us know what it is to help the community avoid said app which would be a far more constructive post...thankyou
Tune Your Android
