Root What is the appropriate overclock settings? (CM7)
CRUMBsnatcher
My cpu is currently set to Minimum:245 and Maximum: 614
It's been slow lately, what are some settings that work better?
how do i overclock bobz07082011 some one please help cant figure this stuff out
go to; Settings, Cyanogen settings, Performance, waring sign comes up, click ok, CPU settings, & Max CPU freq. 2 things after you switch settings set your Governs (mine is setup in Smart A$$), & check Set on boot, & your done...
DON'T set on boot until you know you're going to run the new settings ok. If you do, and your phone can't handle the new setting, it can shut right back down after reboot. Can be hell to fix without re-flashing ROM.
