I have install IGO and I want to know is there any other better gps?
barryyam Well-Known Member Nov 21, 2010 156 1 Malaysia Dec 9, 2010 #1 Dec 9, 2010 Add bookmark #1 I have install IGO and I want to know is there any other better gps?
suhel28 Android Enthusiast Nov 2, 2010 693 307 India Dec 9, 2010 #2 Dec 9, 2010 Add bookmark #2 Google maps if you use mobile network... or else sygic and Igo is fine Upvote 0
suhel28 Android Enthusiast Nov 2, 2010 693 307 India Dec 9, 2010 #3 Dec 9, 2010 Add bookmark #3 ... Upvote 0
barryyam Well-Known Member Thread starter Nov 21, 2010 156 1 Malaysia Dec 9, 2010 #4 Dec 9, 2010 Add bookmark #4 IGO is ok, the only thing is the map is not updated. Upvote 0
suhel28 Android Enthusiast Nov 2, 2010 693 307 India Dec 10, 2010 #5 Dec 10, 2010 Add bookmark #5 yeah offline gps have such problems... i prefer google maps in the cities for highways offline maps (Sygic) is fine.... Upvote 0
barryyam Well-Known Member Thread starter Nov 21, 2010 156 1 Malaysia Dec 10, 2010 #6 Dec 10, 2010 Add bookmark #6 I havent try google map, maybe you are right. Upvote 0
suhel28 Android Enthusiast Nov 2, 2010 693 307 India Dec 11, 2010 #7 Dec 11, 2010 Add bookmark #7 barryyam said: I havent try google map, maybe you are right. Click to expand... the google maps in your phone will show you the maps and destination if you want your location on your map to move along with you use the NAVIGATION application that comes along with out phone atleast that's how it works for me Upvote 0
V vheen03 Lurker Nov 20, 2010 8 1 Dec 11, 2010 #8 Dec 11, 2010 Add bookmark #8 I use the MapDroyd for offline GPS Upvote 0
