Root What is the correct path...
Kaleb Randleaxe
for keeping root when the 2.2 OTA hits? I'm currently running 2.1 root with the REVOlution theme, and I would like to keep both when I upgrade to 2.2.
People that kept root after installing the leaked version of froyo had their su file in the xbin folder (instead of bin). Rooting with universalandroot does this for you, but since you're already rooted, that doesn't help much.
D13 is correct, upgrading to OTA will probably fail if you have installed themes. Here's help with that: http://androidforums.com/droid-x-al...ase-universal-theme-remover-return-stock.html
D13 in
I think I like D13 better than droider:D
Motorola has gone on record saying that no one will be able to OTA update if they have the Leak ( and assuming any derivative there of) already installed. They only way you will be able install the OTA is by running the .sbf to bring you back to stock 2.1.
You may be able to root again, move su to xbin and see if you stay rooted on the OTA. If not you can most likely use the droid 2 root method to root again. But I would just wait till someone roots and de-bloats the new update and install that LOL
yeah I thought droider13 was a play on droideris, you just had to mod it because it was taken
holy crap, I never noticed that, it is blowing my mind right now
the only thing I have owned is the droid 1 and the X
droider13 droideris
no 13 is my number in hockey and I am dumb and uncreative so droider 13 arose
