AaronEmoBoi
Member
i know that you cant root on 2.2.2 and thats the main difference but is there any other differences in the two?
so you can root 2.2.2? wow then i might use itYou can root with gingerbreak.
2.2.2 had a security update to make root harder but I used gingerbreak to root both an optimus and an admire also an m835
Ah i c i just want it rooted to delete the bloatware
Give it a try it might work, give it like at least 12 minutes to try rooting before giving up on gingerbreak![]()
OK so what is the difference between the 2.2.1 and 2.2.2 besides rooting issues? was the update done specifically to prevent people rooting? or was it a system upgrade that actually helped our phones work better? was it done for the continuous rebooting phones problem? and if you dont have the rebooting issue would it be worth upgrading to 2.2.2?
