Root What is up with TIBU and ROM Manager??
Bankswood
Android Expert
Like the title says, since the .340 update bith of these fairly stable and dependable apps don't seem to work very well anymore?
Note that TiBu and Rom Mgr have both gotten updates in the past couple of days as well as just today. Make sure you have updated them.
Thanks Steven, doing it now. Have you seen an improvement in their performance. For instance, I could not get ROM Manager to backup or load roms.
No, I never had a problem with, although gmb had an issue with TiBu.
I installed updates while on the road today and decided to reboot and ended up in a boot loop while driving down the road (trashing my DarkSlide 4.0 in the process). (I know, I know, but Midwest country road with nearly no traffic.)
Ended up restoring a backup so I could have a phone again.
A big +1 there. Funny he posted this after recent updates. :eek:
In any event, TIBU is running like a champ after the update today on my phone at least.
+1
TiBU is running perfectly here.
You have development turned on, correct?
ROM Manager has always been hit or miss for me. Sometimes I need to pull the battery and run it again for backup purposes, but honestly, you could just do the backup manually, and re-name the file after (make sure to not use spaces in the name).
I don't use ROM Manager to restore, or load ROMs, because I do it through clockwork manually, so I can't comment on that.
Anyone running Fission or Rubix... Is TiBu Batch Restore working for you? I get a soft reboot every single time I try to restore my apps. It works fine on Tranq, but Fission & Rubix give me problems.
