Root What kernel should I use?
pandacookie
Panda-riffic!
I'm running MikG 2.61 on my phone. I'm looking to gain better battery life. Which kernel should I use? I don't wish to overclock. Just to get better battery life. Thanks in advance!
Once again, I'd suggest aggressive freedom for lots of undervolting.
I'd suggest running setcpu with it though to max your performance
I'm running more freedom on my phone with mikg 2.61 and I'm not that impressed. It had worked OK on older versions of mikg so I'm not sure why it seems lackluster now. I might try out chop suey
Its different for every phone.
Mine has no issues at 1113MHz, but I havent pushed it any higher. With smartass the phone hardly goes up to my max anyway
