...how do i get the droid x multitouch keyboard for my evo on 2.2???
LOVED Swype until I couldn't get it anymore (I wasn't part of the Beta), and tried all the others: SwiftKey, SlideIt, Shapewriter, Ultra. I really liked SlideIT, but the demo expired and I thought it was too expensive to buy - plus it drove me crazy that it didn't have symbols available on long key press. I tried SwiftKey again (even purchased it), but went on to Shapewriter because I can type much quicker on a "slide" type keyboard. I grabbed Swype again from the link provided by Raezk (above) and was so happy to have it back ... but then I decided to try Ultra on a whim. I didn't know it would swipe so I'd never tried it before. I absolutely LOVE the customization you can do on it. It lets you change basically EVERYTHING, including the size of the keys and what it does for almost all the actions. The best part is it has voice recognition in it AND it has arrow key navigation (something I missed having in Swype). So, it kind of put all the things I like into one keyboard. AND it wasn't expensive to buy. The demo is good for 24 hours, but I didn't even make it 24 hours before I decided to purchase it.
So Ultra has the swipe capability? If so, i will give it a try as well.
YES YES YES. But you have to enable it. Ultra calls "swyping" Tracing. Look for it in the settings, then you have to enable it.
Is this Sliding called Tracing connect to the Nuance T9 trace ?
Huh? Ok, not sure what you're asking, but you can trace with a reqular qwerty keyboard on Ultra.
this is Wat I meant:
http://www.youtube.com/watch?v=vAjIA0HSWVA
Also curious if there is a droidx multi touch to run on stock (non rooted) evo with 2.2??? I have looked at XDA til my eyes are crossed and have not found it.
two points.
2. Direction arrows on Ultra? Yep its nice, of course there actually ARE arrow keys on Swype, check my thread here http://androidforums.com/htc-evo-4g/117125-swype-menu-you-didnt-see.html or just swype from "Swype" key to the "SYM" key. Bingo!!
Wow, Ultra Keyboard is the shizzle
