Hi there! I'm new to the forums and to Android itself, so would you mind explaining to me how to get this keyboard? Thanks!HTC _IME Mod is the best keyboard, because you can use gestures to delete the last word or the whole text input.So for example i have swyping down set to deleting the last word i typed....this way is much easier rather than using the delete key.![]()
Awesome, thanks!
oh you need this other file as well to calibrate it argh let me upload it....install it just like you installed the keyboard then you can calibrate the keyboard.
Thanks!Oh, totally missed this. I can't seem to install it on my EVO though. What'sit do if I may ask?how are you liking the keyboard?oh you need this other file as well to calibrate it argh let me upload it....install it just like you installed the keyboard then you can calibrate the keyboard.
http://files.myopera.com/iblostboy/files/Clicker_hi.apk
K, I tried the HTC_IME and Swiftkey keyboards, and they're missing something I'm rather fond of...the little button on my stock EVO keyboard in the lower left that makes the keyboard go away. I'll likely use the stock keyboard for now until someone else adds that to theirs.Thanks!
