Tbere was a batch of duff SanDisk 64GB cards that they have owned up to. A lot of people had similar problems.
I shall be buying a new one shortly and I am taking no chances and I shall be buying a Samsung card. After all, Samsung makes a large proportion of the chips in these cards anyway.
I agree, class 10 is the way to go since they don't cost much more money than slower classes. My wife and I both have 32GB versions of that class 10 card and couldn't be happier.Yes that can be used, but class 4 has awfully slow read/write speeds. I'd highly recommend one of these if you have $25 to spare.
http://www.amazon.com/SanDisk-MicroSDHC-Memory-Adapter-SDSDQU-032G-AFFP-A/dp/B009QZH7BU/ref=sr_1_1?ie=UTF8&qid=1370540639&sr=8-1&keywords=micro+sd
Even though I knew about the duff batches of cards,I still took a gamble and purchased the 64gb class 10 SanDisk
No micro card greater than 8g has ever worked properly in either my s2 or s4 and I've tried cards from kingstan, scandisk and even Samsung, quite frankly it's absolutely shocking that Samsung can't manufacture a phone to handle more than 8g. Happy to be proved wrong but I have found no info online to solve this problem.
Or:Been using a Samsung 64GB card for about 7 months, worked perfectly in the Galaxy S3 and works just as well in the Galaxy S4.
If they are not working above 8GB and you can reproduce it your phone is faulty, get a replacement because that is not normal.
