I have only 8gb ... If I plan to change it to 32gb ... Is it safe or much safer if I stick to 16 gb??? And does I need to just copy from one memory card to the new one /?? Thanks
I put in a 64gb sandisk ultra, the phone tells you its not compatible and gives you the choice to reformat the card........press ok and hey presto 64gb SXE.
XE specs indicate support only upto 32GB. Better load your card considerably beyond 32GB and check if you can retrieve data correctly... just to be on safer side.... if ok, then nothing like it.
BTW, I got 8GB with my XE. Looks like 8GB for Asia region.
Mine came with a 16GB SD Card. I think its depending on your provider. I'm with 3 and a friend of mine is too with the same phone and got the same. I have a feeling o2 only do 8GB but don't quote me . Think it was a friend of a friend mentioned it.
Both of my Sensation XE's came with 16gb cards. Both on O2 Ireland. Lost the first one with the expensive 64gb Sandisk onboard and my new one (which I had to buy) has a Sandisk 32gb Ultra on board.
