Rob.G
To add the phone icon to your Notification Bar, you will need to create 2 profiles.
First profile creates the icon and notification when you start your phone.
The profile is Event > System > Device boot.
Task is Alert > Notify, in Title say Phone or whatever you want, select an icon, probably the phone icon, be sure to check Permanent.
The second profile is Event > UI > Notification Click, in the Title line put the title of the notification you used (Phone) it is case sensitive so be sure it is right.
The task is App > Load App, select your Phone app in the list.
Now when you start your phone (then waiting for Tasker to start) an icon will be there. You could also go back into Tasker after you applied the changes and go in the first profile and hit Test, that should start it for you right away.
It's on, it should be working, but it isn't, and I don't have anything else running that should conflict. Except maybe my screen task, which I only have because my X keeps insisting on turning my brightness up for no reason (even with auto unchecked).
