nand backup = after root. simple root is just a METHOD of rooting (it's simple) and it is full root, recovery is... someone else will explain that better. basically, using simple root will install a recovery automatically and then you will be able to backup and boot into your recovery that you installed with the FULL root using the SIMPLE root method.
we green?
