Whats better ATM?
I don't know about cm9 but I've looked into.cm10 and its got alot of bugs. And it doesn't have the stock task manager that i love. And can't send media messages. I wanted a cm rom but I'm not impressed with what I've seen. So I'm running stock with an oc kernel. In order for me to flash a ROM its gonna havE to be better than the already good stock ROM. And give new features, not take them away. Just my opinion on cm10. :rolleyes:
Whats better at the moment? a stable CM9 or a CM10? what has the better batterie, and performance? guys think?
I may try CM10 once they figure out the bugs. Rooted Stock works great for me. adjusted cpu voltages for battery life, and removed bloatware. This being my primary phone, I don't need to troubleshoot bugs at this point.
Codegerm
Im using the wicked sensations rom with the blue kuban kernel n it is fast n snappy. comes with 3g n 4g wifi tether hack. fully customized. like having a new phone void of bloat, very stable. bugs need to flash a hotmail fix for the generic email. i just DL the hotmail app. gps works, 4g works n you can go from agat to this rom. QBKING77 has a vid on you tube, th thread below th vid he says agat to this rom is fine, it worked for me just fine. check it out
I don't know bout you but I'm on boost and cm10 works flawless. Evertging works. And yes I'm on boost. Running paranoid android.
I'm running CM10 as a daily driver and it's pretty bug free besides the low volume problem. The MMS fix that was posted a couple weeks ago fixed the MMS problem. I installed the stock task manager from my titanium backup. My battery lasts the entire day without any tweaks. like 9or 10 am to 9 or 10 pm. most of that is idle though.
how is the battery life under heaver usage? My phone is not spending lots of time idle (the new toy syndrome lol)
Codegerm
