Fuzzy13
Extreme Android User
Other than the actual theme files within the zip, is there anything else that depends on whether not you can flash it? Like the build.prop. Is it NEEDED to be able to flash or can you flash without it?
I always have trouble making the themes i create, flashable. They will boot loop one second and they it wont. Makes no sense. They only time I get can it to flash right is when i just take the files out of an already established theme that someone made and add my files. Can never get it to work right when made from scratch. Thoughts?
