Shouldn't happen. This would happen if widgets are moved to SD but a couple sound like system apps coming with the rom.
Are you using theme chooser? If so, does it also happen on the default theme?
He means the CM7 default theme (via the "Theme Chooser" app).
Default will be there in theme chooser. This basically uses the existing frameworks as the theme instead of using theme chooser themes. It must be there or its broken.
Try clear data on theme chooser then reflash the Rom. This may also fix issues with adw which I believe is part of the Rom.
I would also recommend trying go launcher as imho its better,than adw by quite a lot
Yes...I set it to System. However the same issues are present and I believe this is a conflict between ADW and ADW EX. I have installed Go Launcher (again) but there are elements I don't like such as the inability to resize the dock and dock icons and lack of invisible/visible dock bar) etc. I gather Cyanogen is working on the dock size and is included in the latest nightlies - but I haven't checked this personally.sorry, try setting as "system". Its been such a long time since i used theme chooser. I stopped using it because my widgets in widget locker kept disappearing after reboot. Hence why I am so for you to set it as the default "system"![]()
did you?
hi muzzman
warning! i wouldnt use ADW anymore as it failed on me recently while on cm7 - it totally stuffed up my phone and i had to reflash the rom! shame as i had used it for a long time - im now on Go launcher and finding that good
cheers
dan
Dont know what you.mean by this. You can have a dock background or not. Not = invisible. Same with icons. You can make transparent ones.
Go beats every other launcher by quite a lot. Adw is stone age
Ok, perhaps hidden / unhidden would be more accurate. With ADW EX you can pull down the dock bar to hide it and pull up again much like the notification blind.Dont know what you.mean by this. You can have a dock background or not. Not = invisible. Same with icons. You can make transparent ones.
I haven't discovered his yet! What I have found is that Go Launcher is going to make the Dockbar and dockbar icons resizable so that will no doubt mean I move across.Go beats every other launcher by quite a lot. Adw is stone age
Just to finish the thread. I have moved to Go Launcher EX and it is stable on my setup. I understand there are plans with Go Launcher to make the icon size and dock bar size able to be changed as in ADW so I will look forward to that. Thanks for the advice.hi muzzman
cheers
dan
