Well put the .apk on your SD card then open it using astro or some file manager. When u open it, it will prompt you to install it. After its installed it will be along side all of your other applications.
Before trying to install it make sure you go to settings>Applications and check "unknown sources" or it will not install.
.apk is just an install file if im not mistaken. Once installed you can launch it.
What is someone does not have a SD card ? then where can he put it on the phone ?
I can see it been a while but just thought i'd clarify, the folder you want is located in the root directory:
/data/app
FYI - those are the user files. or the system files look in:
/system/app
I advise using 'rootexplorer' by 'speedsoft' in the android market to explore these folders. Commonly promoted alternatives such as 'astro' are s#%t.
Don't know why the rest of you were so secretive and kept drifting off subject about such a straight forward question, defeats the whole purpose of a forum.
If you don't know the answer then don't comment.
THX derrend, and I totally aggree with you.
Not to hijack the thread, I'm looking to get rid of smart task manager, I can't install the sprint family program because it's a business account.
