Root where are they?
zaphodbebleebrox
I deleted. Talk.apk & talkprovider.apk, gpt lucky & found them online in a zip file someone had. Downloaded them to the SD card.
I had to INSTALL them for some reason for them to work. I wanted to just move them to system/app.
MY QUESTION is where did theOS put the files when it installed
Them.
They are not in system/app & they are not on the SD. Card. I would like to move
Them back to system/app so they wouldn't have to be installed.
I deleted. Talk.apk & talkprovider.apk, downloaded them to Sd.
I then INSTALLED THEM.
Them.
They arnt in system/app & they arnt on the sd. Card. I would like to move
Check /data/app
Nope senior, not there. i have ES file Explorer and still cant find them though
iam not positive iam using its search properly. because a search doesnt find them.
Can you confirm that the app installed and you can run it? /data/app and /system/app are the only places I'm aware of that the apk could be.
