Am I the only one that can't get ics yet? T-mobile says it came out 6/11, but very slowly(?). Kies makes no mention of ice cream sandwich and says I have the latest version of firmware (2.3.6), which I do.
Anyhody else still waiting?
You're not the only one. Same here
Thanx, Atmazzz-
bv=UVLDE
b#=GB.UVLDE
I'm a little bit nervous about Odin because my internet connection is flighty at best on my computer. I don't know what the problem is with that. I don't know how many times it took me to finally dl the whole Kies, which I guess was for nothing after all.
Do you agree that Odin could be risky business under my circumstances?
Thank-you
Your internet connection would only be a problem if it causes the downloaded file to be corrupt. You can check that before you flash with Odin. At the link at XDA where you download the file you'll see an MD5 number for it. (such as MD5: B6DD110BD2F6CF6AB6DFC0D834439B65) You can download a free MD5 checker and use that number to check the file.
I don't know why Kies isn't giving you the download. Your baseband and build look correct for Gingerbread.![]()
Since Atmazzz answered all of the questions I will just crack the joke that was like the pink elephant in the room. The Ice cream sandwich that you desire is in the freezer sir!!!!!![]()
Good thing or this heat would destroy it! (MO)
I have a new hard drive in my pc (500gig!) but no program to extract Odin.
Whats that one called...ar or rv or rar or something?
thank you
Hi sleedeane. What you are looking for is winrar. It is a free download and comes in 32 and 64 bit versions.
Does this look right so far:
I'm not sure what I'm looking at. It looks like you have Odin extracted. You will need to just double click the Odin 1.85 file to start it. You don't need the UVLDE file unless you're going back to Gingerbread.
So do I have the ics file downloaded right now?
Whatever I have is from the link at the top of the thread you pointed me to.
Thank you
I guess I'm too stupid to do this.
No your not. Its just a little confusing at first.
No your not. Its just a little confusing at first. Download the file from here or here. Use winrar to extract it.
Then follow this guide. Just follow the steps in the guide, except you don't need the stock UVLDE rom. You'll be using the ICS file you downloaded.
Go to this link.
When you get there, click on the button where it says 'start timer' (where I have the yellow arrow pointing). The timer will count down to 00 and you should be able to download.
Tried that. Timer button does nothing when clicked on.
I'm not sure what the problem is. When the 45 second clock counts down to 00 you should be able to download.
Do you have a different browser you could try?
