Root wheres my launcher
aaronmach1
ok loaded smoked glass v6 and helix launcher came with the install like i chose it too. now the helix launcher is on my sd-card but how do i make it so i can use it? All it did was download it onto my sd. Also same for Audio toggle.thanks!
Get a program like AppsInstaller from the market and you can use it to install the .apk for those apps. You will have to check Unknown Source in menu>applications.
