Root Where's my Nanadroid option?
LittleRedDot
Just followed the guide and everything went smooth as butter, and according to the guide I need to do a nandroid backup, but I cant f ind the option anywhere. Can someone please help?
Just in case you haven't been welcomed yet........ WELCOME TO THE FORUMS!!! :D
I assume you are still on clockwork mod recovery which is what revolutionary loads in your phone.
If you select backup and restore from the main recovery screen select backup. This is a nandroid backup.
Make sure you keep a copy of this nandroid in a safe place because this will have your WiMAX keys included. :)
well, I don't know if the nan can be saved with tbp, but you can just upload the wimax file using dropbox app on your phone.
