I am trying to upgrade my sensation XE to ICS but whenever I try to install, there is a White Triangle with Yellow Exclamation point above a Blue Android ...and the only solution is to take the battery out....any idea guys???![]()
Is your phone rooted mate?
I would sugest to re-download the update. It may be corrupt. If you have a file explorer such as ES File explorer goto /sdcard/download/ & delete the original update, I think its OTA_PYRAMID_LE_ICS_35_S (something somthing).ZIP
Then goto Menu>Settings>About Phone & check for updates again. You should be able to re-download it.
Have you tried a manual install, not sure if rooted phones can up-date to ICs OTA?
