Help White Wi-Fi Bar?
kaivorth
I can surf the internet fine and everything, but I cannot connect to Google Play, so I'm assuming I can't connect to Google Servers? I used to be able to....any suggestions to fix this?
Restarting it usually solves it though...but I don't want to keep restarting.
Try gong to: settings/accounts and sync turn auto sync on and long press the sync dot. Sign in to your google account from there.
Does it show a little add account box below the Auto sync. Click on it and then sign in to your google account. If you haven't managed to already sign in to your google account. I'm not sure by looking at your last post if you couldn't access the option or after signing in to your account it still didn't help.
Try going to the Play Store on the PC and see if you can set things up?
