Man, I don't know, folks. Senseable 3.1 is running so fast and smooth.. I doubt if I'll be wiping for a while.
710/528 helps, of course.![]()
that odd. jrz you may need to wipe the ext also.
and screenshots frisco? just check the wave. theres TONS of info and screens.
im removing the wave though. cant trust pepole anymore. someone keeps removing the links for the downloads.
and sorry if it seemed like a secret frisco, i just havemt released it on any other website than the wave
If you remove the wave where will we get this ROM. This is THE FIRST one that has kept me away from the Official ROM for an entire day. This is without a doubt the best non HTC-centric one floating around I have seen.
I flashed 4.1, and I keep getting force closes on LWP...and Nexus Launcher....any ideas?Im not sure, but im not going to keep the wave up for people to **** with whenever they want. everybody has been helpful, but one person can ruin it for everyone. i need like a hosting site or something.
if anyone knows how to set me up something like that it would be awesome
it doesnt work (lwp).. :-(i havent used LWP so im not sure.
just do a nand backup. thats the point of them![]()
I like the look of this, but its too buggy for me...Ill still with Aloysius Snow for now, until you fix the bugs....great work tho.
No disrespect meant bro....I just like a ROM that EVERYTHING works on...What bugs are on 4.2???too buggy? what bugs lol. there arent ny other than the LWP
mines is actually the most stable CM build.
could you post the link for 4.2? All 3 would be great too ;-)4.2 kickin ass on my Eris, it is quick. Im clocked at 710. My girlfriend has been ticked cause I keep staring at my phone. It is totally diff, in a good way.
I must just be luck. I flash about every rom I see. I am a tinkerer and I have not had problem one. I have not however, actually used the control panel I may have rolled back to 4.1 but I dont want to screw with setting it back. Unless I can just flash 4.1 over 4.2.
This rom is pretty damned tight.
im glad you like it, thats why i put it out
im thinking of building a sense based rom next, theres a few things i miss about the sense roms. also brought an application dev book on my trip, gonna be working on that pretty soon.
and go ahead and try 4.1 over 4.2, just do a nand fist just in case
