i set it up but have no where to use it
I haven't actually used it yet, but I did set up my account on it. I'm itching to try it out though.
You should be able to use it on London Buses from Thursday:
BBC News - London buses to offer NFC contactless card payments
I really want to set it up, just worried about all the nonsense I hear with it being really dangerous and that people can link into your account and stuff. Even if you wipe the device and what not.
However I'd really love to use it in Macy's while Xmas shopping...lol
I don't understand the concern people have. Your card information is stored in the cloud from what I understand. Also when you use Google Wallet you have to enter a PIN number the same as using a debit card. IMO using a credit card that doesn't require a PIN to use is less secure than Wallet.
Plus, what are you more likely to lose, a card or wallet, or your phone? I know me personally my phone is almost never out of my possession or sight.
Yup. I've always been a fan of using a phone as my wallet. I'm not one to set my phone down and walk away. It's pretty much always in my pocket or within reach.
Back when I had an iPhone, I had a slim case that had a slot for two cards. I loved it. ID and one card, all I needed, no need for a wallet.
I love the Starbucks app. No need to carry a SBUX card with you anymore, just scan the phone.
This ties all that together. I definitely plan on utilizing this feature early and often.
Charlie I switch phones like underwear, I'm just concerned that the info doesn't get wiped if I sell the phone..I guess its a legitimate concern?
Other then that, I'm all for it! My phone goes everywhere with me...
Something else to think about, you can turn nfc off or on as needed.
Also, it is off if your screen is off or locked. To use Google Wallet your screen has to be on and unlocked (won't work if you have a pin, password, face unlock, etc set until you are unlocked)
Go to wallet.google.com and on the left you will see devices...
You can disable any device that has ever been linked to the account from there. ...
The first time you open Google Wallet on your phone it will walk you through activating it and allow you to add cards and show you any cards you already have listed with Google. It will also have you setup a pin number.Hmmm, what am I missing, please? The Play Store states that I have Google Wallet installed on my Nexus 4, but I don't see it in "Settings -> Apps", and when I select "Devices" on the left of the wallet.google.com site it states "You haven't activated Google Wallet on any devices."
Following the "Learn more ..." link only leads to a circuitous offering: "To use it in-store, you need an NFC enabled phone." which I certainly have with NFC enabled in Settings, even though it's not pictured there. The "Download App" button merely takes me back to the Store showing that the app is already installed.
The question is, how is the installation recognized so that I can disable it if needed, as you suggest?
I have not used it yet, but one of the things I keep thinking of is often when you use a plastic card they want to see the card and then they can see your 3 digit security code from the back and then it is much easier for them to illegally use the card on line. With Google Wallet that doesn't happen.
