I dont want to use internet calling.. I can't make any calls at all
If you go into settings and make the changes I outlined in post #2 you will find that internet calling will only be enabled for calls initiated by internet calling apps such as viber and will not be used for 1x calls at all. Give this a try and get back to us.![]()
Thanks so much.. works fine now
No, but you can get it set so it tries to use internet calling for all calls, it's a bug imho. It gets screwed up and fails to ask if you want to make an internet call or a standard phone call. Disabling the setting (setting internet calling for only internet calls) resets the defaults and resolves the issue.
