Thanks, but how do I do that? Root explorer?
The only other option would be to use a PC and try to download the apps from the market.
I'm on 3.2 right now, what's an app you're trying to download?
Weird, changing the model to ADR6400L always enabled every app in the market except those blocked by VZW like wireless tether for example.
I did have problems with the market updater in 3.2, and it not downloading apps. I side loaded the newest market after uninstalling it and everything has been fine since then.
Wonder if that had something to do with the errors you were seeing?
On the pc the market shows me having 2 phones, one is HTC ThunderBolt, which it shows as compatible, and the newly named adr6400L, which it shows as incompatible.
Ok, this will show my inexperience, but sideloading is using mass storage right (from pc)? Where do I get a new market link at? Do I place it on my sd card or the root?
Yeah my PC shows 2 devices, except it says both are compatible. Doesn't seem to matter which one I send an app to, it'll start the DL.
Here's the link I used for the market (Download: New Android Market Version 3.4.4
ok any reason for my backup that i made tonight listing being dated as 1/6/1980????
