As everyone waits to install the OTA or thinks about putting on the leak, I have decided not to install it when it comes to my phone for the following reasons.
Hey, I get what you are saying. And it's not really that bad of an idea to wait until more people report getting the OTA and confirm all is good. Right now, there are not that many reports out there of people actually having it.
It's your choice of course, but here are my thoughts FWIW....
1) No new bluetooth drivers
Well... neither does 2.1 and you use that. And if you continue to, you still won't have them. So what's changing?
2) Battery life doesn't seem to be improved
Mine has. It's not a huge improvement but it is an improvement. And as long as it hasn't gotten worse, it wouldn't matter to me.
3) Several reports of the phone lagging and just not working after installing it resulting in the need for a factory reset. Ill pass on a reset thank you.
4) Reports of HTC sense issues still with FROYO
I haven't seen many credible reports of this. And better yet, I haven't seen a single report of people having problems with the official leak. The OTA will install over the phone and update, similar to what you would do when you upgrade Window's and choose the "upgrade" option which keeps all of your old settings. The leaked OTA will flash the phone and completely wipe it before installing 2.2.
Anyone who has ever spent 1 day working in IT will tell you that it's ALWAYS best to do fresh clean installs. I suspect that is the reason that we are seeing a few reports of problem OTA installs but none with the leaked. Which is why I went with the leak.
Hopefully there will be a second release that fixes the bugs, then ill install it, or wait for 3.0, which is due out in January.
Don't hold your breath, my dear
Unless there are major widespread problems, there will not be a second release of 2.2 (it is working fine by most accounts) and we won't see Gingerbread until at least March or April.
All and all, my recommendation is to give it another week or two and then update your phone. But please don't hold out for an update that will never happen or Gingerbread in 6-8 months. Even if it doesn't have a few features you would have liked (like huge battery life improvement or bluetooth) it DOES have a lot of great features. The biggest and most important it's almost 3x faster Quadrant score. Also much better single. And if that's not important enough... you can use the camera flash as a flashlight without rooting!!
