rushmore
Extreme Android User
Ugh.. 2.2 in comparison is DEFINITELY slower performance wise in every way. Gizmodo did some tests and found out that 10.1 flash was actually the reason, but it's just unacceptable how the update seems to have totally caused lag for EVERYTHING on my incredible.
Not having the problems you are. Did you install 2.1 over 2.2 without starting fresh? If the browser is your problem, turn Flash to on demand (Dolphin has the option).
As far as interface and apps, 2.2 is faster than 2.1. No comparison.
Seems all the issues that Sprint and VZW have had with 2.2 would not be an issue if the did several things (the last two are practical):
1. Stop bolting on interface layers to Android
2. Force data wipes for major updates (like 2.2)
3. Provide an official back-up utility for user apps. Built-in, that works just like Rom Manager so apps are backed up before updating. Then a simple restore.
