Blackbrawler
Member
Man if i see this complaint one more time i'm gonna explode.
Look im sure someone has said this already (a little you even said in your post) but
1. Android installs apps into the built in Memory which for droid is (512 mb not 256). A lot of people get this built in memory confused with RAM, which is used to run the application not store and to be honest 256 RAM is good enough for a desktop with windows xp and even can play some pretty good games (Dofus).
2. I've heard that google is working on this, and as long as it is working on it there really isn't a problem because by the time you managed to fill your phone w/ 512 mb worth of apps a ton of new features will be on the Droid.
3. Also the 16gb thing is the very thing that makes Android > than apple, because you have the ability to increase/switch your storage. At any time you can just grab a larger microsd card and put it in. In all honesty you probably wont need more than 16gb and 32gb sd cards are expensive and we don't need to even talk about 64gb. This saves not only phone companies but you money.
4. I really don't know what a PMP is so i can't really tell you to replace it or not but i can tell you that this size problem every one keeps complaining about is irrelevant. I mean i have yet to hear ANYONE actually have to delete an app because they used up all 512mb.
Plus if you root your phone im pretty apps can be moved to ur sd card, so their problem solved.
The only real problem with loading off of SD card is potential pirating, which as a consumer you really don't need to worry about (only devs do).
