cant not connect to my home wifi, has wpa/wpa2 psk (it says). put in my wep and it is remembered but says "unsuccessful" every time. cant connect to neighbors who has barely one bar(its open). Anyone?????
was it in the incredible section? did some searching, saw people w/ same problem in droid area but no solutions.I saw another thread where someone else had this problem recently and discovered that he needed to make a change in his router configuration. I don't know (or remember) any more details about it though.
Never heard of it. What's it do.. or i could just go to market huh... lolHave you tried Wifi Buddy from the market?
Yea been trying, hit the connect button over and over and nothing...Try having your router broadcast the SSID. Some people can get it to connect by simply broadcasting it temporarily while I have seen where other people have had to keep it broadcasting to reconnect. I don't know why the difference but these are some things to consider.
netgear, less than 2 years old, logged into it last night and the firmware upgrade failed... dont know why but laptop works fine with itLongshot but since answers aren't falling from the sky...try changing your wep key and re-entering on your DI when prompted. Could also try adding an access schedule using your MAC address and set it up for 24/7 granted access. One final idea is to update your router's firmware. Actually I might try that first. What kinda router is it out of curiosity?
he might be, gonna try firmware upgrade again, btw a soft reset is just to turn off pull battery and turn back on right?No clue here, but try something simple like a soft reset on the phone.
iowabowtech's on to something though.
firmware upgrade did the trick, Thanks!!!!!!!!!!!
