Help Widgetlocker bug.
Fureeze
I recently installed WidgetLocker on my HTC Desire, and changed the lock screen to a alternative wallpaper with the WidgetLocker clock and the standard WidgetLocker unlocker.
But there seems to be a problem regarding lag or similar. When I press the lock button to unlock the phone, the original HTC Sense unlocker appears for .5 - 1 second, and THEN the WidgetLocker lock screen appears.
Is there anything I can do to stop the HTC Sense unlocker interfering with WidgetLocker?
I'm not rooted.
this only tends to happen if you try to unlock it right after locking it
if you lock it, leave it 5 seconds then press unlock does it do it?
are you rooted? this can be to do with the method it uses to remove the 5 second rule
I too have Widgetlocker. Occasionally it'll display the HTC sense lockscreen. Seems a bit random though and doesn't happen often enough to be an issue.
