Camaro2012
My wifi connects to home router just fine but browser will not go to web and that is even with 3rd party browsers. Anyone else have or had the same problem and if so how did you fix it?
That would be good to know. Is it easy to do?Do you know how to give the phone a static IP address? As I say, that can fix a lot of connection issues.
Can you change to WPA, see if that makes a difference?
Is it an older router? Some aren't compatible and you get connection issues. Is it also just your home network you're having a problem with? Can you connect to other networks fine?
It is the wireless router that Century Link installed but I may have an idea of why it is not working. The Warp is asking for a password and not a wep key, in my router there is a place for a pass phrase and this may be what the warp is looking for as it may not support wep keys. so I will remove wep key and replace that with a pass phrase and use as a password to see if that is in fact the issue. Any thoughts???
. Generally the phone should have some compatible issue with some router I guessed. as you said you have two choices, one is replace your phone and another is replace your router. ask your router's company or service complany they should give you some support. right now replace or upgrade the router is the best way.
