Wifi App/Help Needed
winky
Member
My Hero takes a long time to connect to my home wifi. I usually go in to the settings and hit "Scan" repeatedly before it connects. Sometimes it fails connect, and I have to go into Settings to try again.
Is there a way/app to scan automatically or re-attempt to connect again? Maybe there's something I'm not thinking of?
If you have previously connected to an AP then the handset should reconnect automatically when in range. Only thing I can think of right now is to select your AP in the networks list, choose "Forget" when asked, then try reconnecting.
