jjhelpteam
Member
Can someone give me a link to the Wifi calling on that's on the stock ROM I installed the JB rom and there is no Wifi calling on it.
You can try searching for the .apk but I think its more complicated than that. It probably needs to be built into the rom. Which JB rom are you using?
Thank you very much. But I thought the s3 had JB
I think it has just started rolling out for the S3. I'm not sure if it has gotten to T-Mobile yet.
Well I hope they get it soon... on another note is there any chance of getting rid of CWM with Odin?
TWRP is faster and does a better job of wiping.
