Am I the only one that gets suspicious when people are making their first posts on something like this? If your router or modem is crashing or resetting when you add a device it is your router or your modem that is the problem. It is possible y'all don't have enough DHCP leases running and when you add the Evo it tries to take an IP Address when one isn't available and everything hangs up. Go in to your router's settings and Assign IP Addresses to all of your devices so that they get the same one everytime they connect. Also go to the Support Page for your Router on the Manufacturer's website and check for similar problems and firmware upgrades. Your Evo is not the problem. Download WiFi Analyzer from the Market (it is Free) and check your Channels. If your router is set to Auto Select a Channel actually disable that and put it on the best Channel according to WiFi Analyzer. If you don't know how to set the channel, again go to Linksys, Netgear, etc website and they should have a step by step.
Actually I disagree with this line of thinking. If everything works fine, all of a sudden you bring home a new device, and the router goes haywire. I agree, it could be a problem in the router firmware, but you are just totally throwing out the idea that the phone could be the root of the cause.
I have a trednet router and this also happens to me with my EVO. I agree with previous posters that this is directly related to using the EVO wifi. Randomly after a certain amount of time, it will lock up the router. Sometimes turning wifi off on the EVO fixes it, other times I have to unplug the router to reset it.
Typically when you have a DHCP conflict it will not crash all internet capabilities on the entire router, but instead only the devices with the conflict would have the issue. Also the fact that all the devices work fine at first, but eventually the EVO wifi will crash the router tells you that its not a DHCP issue. Unless the phone for some reason keeps asking for a new IP address at random. And if that's the case why doesn't it ever start working again at random without having to reset the device or phone.
I am looking for a solution to this problem. So far I have yet to find a post where someone can tell me exactly what is happening here. I have no problem with people adding their input, but what i'm looking for is someone who can give technical details as to what exactly causes the problem.
Hopefully in the next few days I have time to run a test that should point us in the right direction anyways. I will be turning off all my devices except for my EVO. If the wifi stops working on the EVO and causes a crash while no other devices are connected, it must be a problem with the EVO or the way the EVO is communicating with the router. Even if its a problem with the router, the EVO is clearly doing something to the router that no other devices are that causes it to lock up.
Details
HTC Evo Running Android 2.2
Trednet TEW-633GR
