avenuePad
Member
So, out of nowhere last night I couldn't connect to my home WiFi. After an hour of struggling, trying to manually set my WiFi as static, I downloaded "static WiFi" from the Play Store. Worked like a charm. I set the connection to static from the app, turned off WiFi, rebooted the phone and then turned WiFi back on and it worked like a charm. I do, however, get an error message when connecting to any WiFi since using WiFi static, but it will connect regardless.
I'm not sure if it's a software bug, which I have heard there are issues, or if it has to do with a security setting on my home WiFi. My Galaxy S did the same thing on my folks' WiFi last year.
Any other solutions or advice would be appreciated.
