Root WIFI doesn't connect after ROOTING Galaxy Note
tsam19
Member
Just to let people know that there is a WIFI connection problem after you ROOT your Galaxy Note on ICS 4.0.3 / 4.0.4
For some reason the wifi icon appears, the message telling you your connected but WILL NOT actually process data via the web / internet
I have tried various ways
help some wifi issues with my galaxy note - xda-developers
But still is a persistant issue when rooted, but after a fresh reset (unrooted no apps etc) wifi will work ! :o
Any ideas or tips to get it working once rooted would be grateful.
Thanks
Move it where you want buddy, what ever makes you happy ;)
As far as I'm concerned the post is closed as I've solved / found the answer on sorting the problem.
Thanks for all the replies - NOT :(
