Help Wifi doesnt work
Feeed
I can connect to any WiFi fine but i get no internet, this have been going on for about a week and im not sure whats the problem.
I tried connection to many different places but its always the same, so its not a problem with my router.
Welcome to Android Forums!
Try "forgetting" all wireless networks listed in Settings/WiFi, power-off and remove the battery for 5-10mins. Power-on and see if that solves the problem.
Check your IP settings as well. I use a fixed IP in my office. If I connect to public wifi say at McDonalds, I won't be able to go online unless I change the IP to Dynamic instead of Static. You can connect to the wifi no problem, but since your IP isn't one of the recognized field, it won't allow internet connection.
