ok so i partitioned my card and flashed the Kinged-Pyramid Rom and i wanted to connect to WIFI but when i go into wireless connections i cant check my WIFI box....on the left hand side it says WIFI error?? any ideas as to why?? and if i can fix it?
Did you flash a custom kernel as well? Be sure to use the correct one for your ROM. I had the same problem when I installed a kernel for God-Mode, when it should have been the Universal kernel.
