Help Wifi Internet Connection Dropping
Leevis
Hi
I have a really strange internet issue. When i am at home using Sky Broadband, my internet connection sometimes drops. I am always connected to the router ie wifi stays on but when i try to get on the internet it doesnt work.
Its fine when i am at work, i guess that it has something to do with my settings on the router but no idea what to do. I changed the router yesterday so that it just broadcasts G and not N but this hasnt changed it either. If i reboot the phone it works for a bit but then ultimately drops again. very strange, anyone experienced the same thing?
Lee
I had also problem with dropping connection when I was using my Sagem SKY router (I almost didnt have signal 4 metres from the router, and no connection behind two walls)
I changed the broadcasting channel from 10 or 11 to 1. Don't know why, but know is much better.
On this one i remain connected to the router/access point, its just that i cannot reach the internet, its as if the router is stopping me
Go to Settings/Wireless & network/Wifi settings and select the wireless connection in use. What is shown for Security, and is the handset using a valid IP address for your network?
Also it might be worth checking the router manufacturer's web site for a firmware update.
