Root Wifi Issues
I've been having issues on connecting to wifi.... i have the sense rom installed and days before connecting to my wifi worked perfectly and all of a sudden today it would stay at the "obtaining ip address" and then just disconnect.... times before i would reflash the sense rom but it continues to happen.... is there any known solution to this?
havent heard of any issues with the wifi.. have you tried reseting your router and seeing if it connects?
I had this same problem. I was messing with the repeater function on my router and it turned my DHCP server off. Log in your router and make sure DHCP is on or you will just sit there waiting for an ip forever.
Also make sure you dont have mac address filtering on in your router, or add the phones mac address to the allowed list.
