wifi notification
aodmisery
whenever im not home and not using the wifi, i cant seem to get rid of the wifi notification saying theres wifis available its kinda annoying, i went through all the wifi options but cant seem how to get rid of the notification. any ideas?
Unfortunately from what I've read it can not be turned off, I'm sure devs will take care of this and other nags in custom roms if you choose to go in that direction.
If your phone is rooted. http://forum.xda-developers.com/showthread.php?t=2014134
On the Samsung S3 there was a special number to dail and then a secret menu would pop up to disable. So it's Verizon causing that persistant wifi notification. I assume that this phone also has a secret menu. But i need somone way smarter than me to find it. Below is the S3 procedure (just so you know). and it does NOT work on this phone because I tried
DIAL *#6335623#
A menu will appear
Select Disable WifiOffloading
yea, this isn't the notification that there is available wifi spots, just says, 'click to turn on wifi'
annoying at first but ive mostly ignored it... I have a widget for that...
would LOVE to figure out how to disable that...
think i will ask the HTC elevate mods if they can tell me....
If you're rooted there's a zip you can flash to remove it from the notification drop down.
From the looks of it, it'll probably be on all VZ phones from now on. Droid Life got an LG Spectrum 2 to test and its got it too, so not just an HTC thing either.
Yes NightAngel, I forgot that was for a different type notification on my S3. But I bet there is still a hidden menu that could get rid of it. Like you I just ignore now.
Sorry to bring back an old thread, but did anyone ever figure out how to get rid of this notification without rooting the phone? I like to leave my wifi on so as not to use up all my data and I tend to go from wifi area to wifi area a lot anyway, but when I'm out and about this notification is ridiculously annoying.
Go to Wi-Fi Settings, click menu -> Advanced and uncheck "Notify me". This is on by default. Unchecking this I never receieve the notification message any more.
I already unchecked that option. I still get a notification on my status bar when I'm not connected to wifi.
Yea, that's not the same one he is talking about.
No way to do it without root, fwiw
