Root Wifi Scan Interval changes won't stick!
cheluz245
Rooted on Romtoolbox I've tried to change the Scan Interval. It says changes take affect after reboot. I reboot. go back to check n its back to default. =\
change it in the build prop file via root explorer then reboot lol...no way it will go back to stock that way my friend
its at like 120 stock, what are you trying to set it too??
120 is seconds FYI and that = 2 minutes
